I had an issue with mine after it sat for a bit, the tank got pressured up from the heat and I think it flooded the engine out
Also make sure the plug is actually firing, pull it out hook the wire back up and ground it to the engine and pull it over and make sure it’s sparking
I had an issue with my plug wire in mine too and it was intermittent firing
Also check/bypass the toggle switch and fail safe unit some people had issues with them
If it’s sparking good and you think maybe it’s a fuel issue squirt some down the plug hole and try to fire it up
If it starts then dies then it’s a fuel supply issue
Now that it’s winter out you prob have to retune it
I doubt the engine is toast if it ran fine two weeks ago and now suddenly won’t
