I get lots of PMs and emails asking about the Super Bees various features. So maybe this will help.
Most of us have a lot of money invested in our gas RCs, and we want them to be well protected from a dangerous runaway. The Super Bee is the best protection you can add to your gas RC, and to prove it, I'm going to list some of the important features that set the Super Bee kill switch kit apart from the competition.
http://www.killerrc.com/product-category/kill-switches/gas/
The Super Bee works with 2, 3, or 4+ channel radios. You can turn the Aux control feature on or off. No other kill switch can do that. If you want to add a light controller to your 3 channel radio then you can easily do so, and the Super Bee will still work. Just flip down the #1 dip switch, and then the Super Bee will only kill when you have a glitch or turn off the transmitter power.
The Super Bee works with 2.4ghz, FM, most PCM, and AM radios (AM radios should not really be used on gas engine RCs). The Super Bee works with analog or digital radios. Doesn't matter how high the resolution/frame rate, HRS, PCM, PPM, 5.5ms, 11ms, etc. There is no radio signal too fast that the Super Bee can't "read". See the radio compatibility chart. http://www.killerrc.com/radio-kill-switch-compatibility-chart/
The Super Bee works with 4 to 9 volt radio receiver batteries, so it's 2S 7.4v LiPo compatible. With other kill switches you have to install a voltage regulator inline for the kill switch to work on 7.4v. That's just more stuff to mess with and possibly fail when you need it.
The Super Bee has adjustable low voltage cutoff. If you want to switch your receiver battery from a 6v NiMh to a 7.4v LiPo you can adjust the Super Bee to protect your higher voltage battery from being over-discharged. The Super Bee works with 4.8v, 6v, 6.6v, or 7.4v battery packs. By the way, you never want to use a generic kill switch that has a 3.0v cutoff, because most radio receivers go into failsafe mode at 3.5v, so the kill switch would be useless. The Super Bees adjustable cutoff is 3.8v, 4.5v, 5v, 6v. It comes set from the factory at 4.5v (4 amber LED flashes at power up)
The Super Bee has adjustable glitch sensitivity, which is nice if you want to drive at long distances without prematurely killing the engine because of small glitches. Some radios naturally have small glitches, and with this feature you can make the Super Bee "ignore" these small glitches and allow the engine to run, unless a significant radio glitch happens.
Twin engine capability. You can turn a regular Super Bee into a twin Super Bee by just soldering in an extra cable (available from us) into the 2 empty holes of the Super Bees circuit board.
The Super Bee has 6v LED output that can power up to 50 LEDs, like 4 sets of HPI Baja LED headlights (that we sell). It will make the lights flash when your battery voltage gets low or if your radio has a glitch. Other kill switches can only power 1 LED, or no remote LEDs at all.
Buzzer output. The audible buzzer reminds you to flip your radio switch before trying to start the engine. Or it reminds you to turn off the receiver battery once you have turned off the transmitter.
The Super Bee is half the size of other kill switches. Its easy to fit in any radio box.
The Super Bee kit comes with a quick disconnect JST plug on the ignition cable, to make it easy to remove your battery box or swap out the engine.
The Super Bee kit has EMI filtered ignition cable, to help prevent radio interference through the cable.
The Super Bee kit is easy to install. No need to solder or crimp any connectors. Just remove the old push button switch on the engine and install our new one.
Engine Temp sensor module coming soon. So the Super Bee can kill the engine if it gets too hot.
Data logging module coming soon. So the Super Bee can send info to your smart phone or computer about your cars: voltage, engine temp, and radio glitches.
The Super Bee is available in a car kit, boat kit, or twin engine kit. This makes it plug and play on most any type of vehicle engine.
The Super Bee was designed and is manufactured in Ohio, USA. We test each kit thoroughly before packing them up and shipping them out to customers.
1 year warranty, and usually we will still fix the parts even if they are older than 1 year. I have repaired a 4 year old kill switch before. No charge to the customer.
We have dealers worldwide. We ship worldwide, Monday - Saturday.
We have the best customer support in the business.
Thanks,
Kent
Thanks,
Kent
