howdedoodee
New Member
good day to you all.
I am about to make a master mold loosely of the design below using the mcd as the datum.
once finished this master will enable us to make many shells.
The shells will be made as follows:
1. white very smooth gelcoat finished ready for painting.
2. 1.5mm 2mm or 3mm thick fiberglass base structure.(thickness as per order)
3.metal micro-mesh reinforcing to critical areas.(wings and front former).
4:we expect these to outlast your polycarbonate shells tenfold.
5:cost will be similar to cost of poly shells.
6:your side dirt guards will have to be removed as body will tuck tight into the chassis as per picture design.
7.your rear wing is also removed.
8.once your side guards and rear wing are removed we expect the weight to be near to poly shells as makes no difference.
9.If we have a lot of interest we plan to make many master molds of wild and futuristic designs to choose from,to include many models.
Please let us know what you all think.
thanks for you time
regards john
thanks for you time
regards john
