I can Agree, its a pissing contest. However, synthetic oils have proven results over regular oils in extreme testing, where most 2-stroke run. Im no expert, but a racer, who built and maintained his own engines. Im a true believer for sure. But I can say, I would not mix oils though, I love castor oils, they smell and work great but mixing them with synthetic would be a bad idea.. Personally, I think Redline Synthetic works the best at extended high rpm with air cooled motors. But... thats my opinion. lolGRIPNRIP123 said:I have seen this conversation play out several times. I am the parts manager at a powersports dealership and an ASE certified tech. I hold certifications from motorcycle manufacturers and automobile manufacturers. I started racing 2-stroke dirt bikes 30 years ago.
All oils offer different benefits. Ask two "experts" and get different answers as to which is better. Go buy a quality name brand oil that is made for your purpose. It is most likely that an engine failure will be caused by something other than your oil.
I have seen problems switching back and forth between oils. Swapping between synthetic and bean oils is the biggest problem.
I like castor oil. Even though I know synthetic oils burn cleaner.
This is just my 2 cents.
Techs at our dealership argue about this sometimes. Nobody ever wins!
You always, even in 4-stroke engines use regular oils to seat rings.. Then when you switch to synthetic to prolong your engine. Its obvious synthetics work if metal on metal contact of the ring against the cylinder walls become protected enough to hinder the break in process.kbreaux100 said:i am basing some of my knowledge off of a thread posted by one of the men at gizmomotors.he stated that of all the problems he had seen with the large scale motors,most were caused by synthetic oils.rings not seating,blowback,and all around crappy wear on motors.as soon as he convinced these people to switch to non synthetic oils,and he suggested qucksilver premium,sold at walmart, theyre problems stopped.he stated that these outboard motor companies,like mercury,who makes quicksilver,have done the most exstensive testing on 2 stoke motor wear and oils,and they have put the most r and d into their oils.the quicksilver premium is not just an outboard motor oil,but is made and certfied for use in any 2 stoke engine.
