MonsterAir
Lone Racer 🤠
- Long Island NY
Scooped this rig off CL recently and will be prepping her for the track over this winter. She had some worn parts on her that needed replacing but over all I think I scored finding this body. Or at least that's what drew me to hand over my cash.
So far I've thrown these parts at it
- Zenoah 29cc top end
- 990 carb
- stock filter
- KM ball ends for each wheel
- KM alloy front shock brace
- KM alloy rear shock mount
- Killer Bee
Am not thrilled w/ these KM rear a arms. Turnbuckles don't hold tight, some wiggle. Put the nuts on but they don't stay, will try Teflon tape next I suppose.
Here is the list of things I plan on adding over the course of winter -
-Hostile adjustable rear hubs w/ IRP ball ends / Seriously considering these though
https://www.ebay.com/itm/New-CNC-alloy-rear-wheel-hub-carrier-kit-adjustable-angle-fit-1-5-HPI-BaJa-5b/112245633288
-KillerRC Turnbuckle Pro Kit
-FLM Drive cups
- 3D printed shock pistons / got a 3D printer and wanna help?
- Anti Squat Plates
- Billet motor mount
- High rev piston
-Lightened flywheel
- MOP/MIP clutch
- +2mm stroker crank
-Snappy fuel vent kit w/ brass fittings
- DT1 Foam triple flow filter w/ Outterwears and velocity stack
-Turtle Racing servo saver
- Alloy servo mounts/braces
-D845WP steering servo
-SB2290SG throttle brake servo
-Rovan Disc brakes front and rear
-1" & 2" hub extenders / only if they work w/ brakes
- Probably new dog bones / any recommendation for a dogbone that the pins are fused into head and not held by set screw? Ran it once and lost a pin already!
If you can recommend anything I haven't mentioned pls do!
I need to figure out how to adjust the front camber. Need them to come in a bit but I really don't have any adjustability with what's on it now
Also need to figure out what I need for these body supports?
- 990 carb
- stock filter
- Killer Bee
- Anti Squat Plates
- High rev piston
- MOP/MIP clutch
