My current project:
1/4 Scale 4wd, 4 wheels independent suspension. Based on Hummer H1 dimensions: 49.5in long, 28in wide (with 4in wheels mounted), looking for under 20" height, 4.8" ground clearance. I'm in the process of designing a 3spd w/reverse manual tranny. So far so good. My other current headache is brakes. I would like to use 4 go-cart based brakes on each wheel. The design is simple, make a thick disk, and then a round strap that can be pulled tight around the disk.
Anyone know what material I could use on the strap to act as a pad?
So far into my 6th year of work on it. Yup 6. This is revision 2, of the third design, so......5 times this thing has been reworked. But now I have it, and it's moving along, especially since I was introduced to Solidworks at work.
Anyway, ask questions, make comments......be nice......
