ok, i wasnt sure what kind of specs you were looking for.
so you have the 1mm stuffed stroker crank installed in a TS Reed case modded with his 28.5 topend.
depending on pipe, and tuning, i would guestimate the hp to be somewhere around 7hp. go over to our sister site HBF, Lunatic did a dyno run of one of trevors motors. has the sheet there, now im the first that will say a dyno sheet isnt worth the paper its printed on, unless your a motor or pipe, or gear builder, but in your needs, a dyno can be reflective of what you can expect to see.
