You need the specific g320 clutch housing. Normal housings will not fit. Yes they do returns, just shoot them an email.
Yeah I just read their return policy. I just realized I threw the bag out..... well ill try anyway but I won't be hurting if I can't. I'll just throw it on my old engine and sell that one for more.You need the specific g320 clutch housing. Normal housings will not fit. Yes they do returns, just shoot them an email.
Do you hear a rattling noise in yours? I'm guessing its the reed flaps opening and closing fast but I'm a bit spooked.Yip luv my reed motor??
I don't have the brakes installed. It sounds like its coming from inside the engine. Its almost like a scrape sound. https://photos.app.goo.gl/R3ErpW9o9UjyT1Fq6I doubt you'd be able to hear the reeds working. Could be the brakes rattling a bit.
I held the pinion and felt no vibrations, even moved it around to see if I can feel rattle. The spur isn't installed yet unfortunately. I may need to talk with the guys at obr about this. Perhaps I shouldn't start it again.Not the spur and pinion ?
Check the coil and flywheel , se me if anything is loose, aswell everything on the clutch sideI held the pinion and felt no vibrations, even moved it around to see if I can feel rattle. The spur isn't installed yet unfortunately. I may need to talk with the guys at obr about this. Perhaps I shouldn't start it again.
Hope you just looked at that link I sent the wrong one before. Right now it's 19/55. Depending on what it does in open grass I might decide to gear up. I won't be able to do that for a few weeks though. Snow inbound.what gears are you running ? sounds way overgeared
yeah i definitely looked at the wrong link lol. sounds great ?Hope you just looked at that link I sent the wrong one before. Right now it's 19/55. Depending on what it does in open grass I might decide to gear up. I won't be able to do that for a few weeks though. Snow inbound.
