You need hostile hubs or similar, the stock hubs will rub even with small flm stuff, they are poop. You can try to grind em out but they belong in the trash regardless ?
Yeah I know. They just don't break so I had no reason to replace em. After drilling them out they fit perfectly now. Ill wait u til it breaks on my next run to replace em lol.You need hostile hubs or similar, the stock hubs will rub even with small flm stuff, they are poop. You can try to grind em out but they belong in the trash regardless ?
It's a baja thing, one day you'll understand ?I want to make a running video so bad however I keep running into bad luck. Last 2 runs I broke something and now this morning first pass my wheel pin gets lost. Welp
You cant. Unless hpi made some (idk) which you can't buy anymoreDidn't know you could get softer then factory
Yep but it was convenient seeing I already had most of the parts otherwise I would have gone with the rcmax one.Diff is a rovan diff right? Doesn't surprise me. Their riffs are about .5mm off compared to hpi.
It's his diff case hitting the trans case, not the gearYou could put a blackbone gear set in there......may solve the problem
I do have IRC cups lol.Gat irc cups
