tyre/rim size???
Whoduh
Fairfax, VA
Those look like Trenchers.
if so, it should say front or rear somewhere on the sidewall????
should be a 5t/ssc rim.
I can check mine when I get home later. I have them on a stock DBXL rim.
Z.hb71
Manvel, Texas
can sumone pls confirm which rear rim I will need for his?20181107_162044 by evssv, on Flickr
??is it a 5t/sc rim?
convert that from inches to mm using a calculator u can find online than look at the stock Baja 5t or 5b tires and see which one matches then just find a wheel that fits that size tire. and it appears as tho u got tires for the stock baja 5t rear wheels or proline split six rear wheels
this is my source https://www.prolineracing.com/tires/trencher-off-road-rear-tires.asp
evssv
Bristol uk
evssv
Bristol uk
5t rears already in me basket....(y)...jus need to decide on dye color and b.lock colors now....:unsure:
