Ultimate Brake Upgrade from OutFrontFrames / Turtle Racing
United States of Texas
New brake system from OutFrontFrames/TurtleRacing with a couple of key features.
No more D-bushings. They have been replaced with bearings for a smoother, slop free operation.
Testing has proven a much more durable brake system as well as much longer lasting, even with the carbon rotor!
Virtually a set it and forget it system.
Consistent braking lap after lap.
Superior stopping power over the stock brake system
Has the ability to lock up the rear wheels on grass, at speed!
Also has the ability to be smooth as silk. The brake can be as smooth as your finger.
Provides more support for high tourque servos
Superior strength to weight ratio
Comes with:
* Turtle Racing Aluminum brake pads
* Turtle Racing Aluminum brake caliper
* New OFF brake plate which attaches at four points rather than three and has been machined to accept the bearing.
* New OFF rear chassis plate machined to accept the bearing
* New OFF Carbon Fiber Brake Disc
* New Aluminum Brake Plate Spacer
* 2 - steel shield precision ball bearings for the brake cam
Available for order by Friday
Price will be posted by the end of the day
OK guys the price has been set at $99.00 USD.
This includes everything needed.
Comes with:
* New OutFrontFrames brake plate which attaches at four points rather than three and has been machined to accept the bearing.
* New OutFrontFrames rear chassis plate machined to accept the bearing
* New OutFrontFrames Carbon Fiber Brake Disc
* 2 - precision ball bearings for the brake cam
If you currently own the OutFrontFrames rear chassis brace the price is $85 USD. You must send your current OutFrontFrames rear chassis brace back to us and we will make the necessary modifications needed to convert the plate over. This only applies to OutFrontFrames rear chassis braces. Braces from other manufacturers will not be accepted. We will do our absolute best to make the changes and get them back in the mail with your kit the same day it is recieved.
Like all of our Baja 5B Carbon Fiber parts, the carbon fiber included in this kit carries the OutFrontFrames Basher-Proof Guarantee.
Quantities for the brake kits will be limited at first. However, they won't be limited forever. :D
