Using high-heat red thread lock on exhaust header bolts
neeper
Vancouver, Canada
I try to avoid using red thread locker anywhere possible just because of the extra work of applying heat to remove.
For exhaust header bolts, I've always just used blue loctite and along with lock washers. Are you guys using high-temp red loctite on these bolts or using blue with lock washers okay?
Z.hb71
Illinois
With my old 30cc my exhuast bolts kept falling out, so I did red Loctite with lock washers and it worked fine for me. I was still able to remove em but I'd heat em up a little before lossening em
pyroM!KE
New Member
I have always used a very small drop of red loktite on the exhaust bolts. Never stripped anything out and I don’t even have to heat to remove. Use sparingly. Holds bolts in nicely
