Vesla Cage Tab/Mount ?
cmbscx10
LSF Plus Member
PLUS member
Ramona, CA
I looked and looked but can't find out a pic or description on what the Circle and Arrow tab/mount is for.
at a guess fella its the mount forthe kraken quick fill gas setup (y),
i had one, (still have it actually) it was a bottle with a spring valve in and a tube that ran to the fuel tank, the tab took the flange that the bottle plugged into for so ya could fill up easier or without having to take the cage off etc,
had mine on a tsk-1 cage,
Is there a quick disconnect kit for vesla? I saw DDM has some quick disconnect parts for vekta, but I wasn’t sure if they’d fit the vesla
Thanks for all the info gents. I honestly thought it might be for a light bar.
Not that i can see so i will likely use the Vertigo Vekta pieces and cobble it together.
This is the only one i could find? It is just tethers from what i can see. Any links to the one you saw?
https://www.detroitperformancerc.com/product-page/detroit-performance-cage-clip-and-tether-lanyard
I emailed DDM re: a Vesla system. Below is what I got in return
There are currently no options for a quick release option for the TSK cage for the VESLA/Baja. I know that Vertigo has looked into it. I will see if it is a project he is going to keep pursuing.
thanks
Steve
