VESLA owners !!??
Braapster
I’ve received my Taylor 71 for my VESLA , kraken doesn’t list a gas version manual I Geuss , I need help figgern the correct engine mounting bolts ( all of them ) , if there’s someone who has a manual for the gas version or maybe another solution, ide sure appreciate it thanx
Yes , I need those and also the four that go through the gear plate to the engine , after further review I saw that manual , thank you for your help , I saw part #kvs149 , it’s a bolt kit for VESLA , but cat figger if it’s gas or electric version stuff , waiting on Taylor , ddm , and Detroit performance to call back and try to get it figgered
Yes sir , I’ve completely upgraded everything, big block tranny case , backbone gears , layshaft , it’s been a long road to get to this point , now I just need to find some dam screws !!!
Yes I’ve looked at that , the part #’s don’t work at all as to locating them on there site , I’m hoping this part # kvs149 is a screw set for both gas and e versions , thanx for the input
Funny. Better than the dogs i see at my AH.
This is what i do for any RC volt that is load bearing. Measure the depth of the hole and the thickness of the xyz part. Subtract 2mm for inconsistent drill hole or threads and get the nearest length.
For my motor the M5x16mm above are now M5x20mm. Overkill? Maybe but my motors don't vibrate loose or move. Plus the extra $.02 is worth it IMO.
Dark studios , pretty cool stuff !! Just waiting on some washers for engine mounts and a killswitch and I’ll be putting the beast together soonly !!
We have busy beaver stores in Pennsylvania, great hardware section, rod ends, all kinds of goodies.....Have to put in a bag and write how many and price per each....old school trust system.Stay away from home depot,lowes, junk cheap bolts....
