weak rear diff cases on evo 3?
this only ever breaks if your small bearing on the pinion seizes and heats the plastic up or the 2 bolts that hold it together are to lose or to tight
i have broke only one and this was because of a sezied bearing due to using the car in the wet
i have had mcds for over 2 and a half years and never broke one for any other reason
best regard stevo
thanks, will check bearings both bearings, and see what i find. as for those two bolts, i can turn the scre on bottom of chassis and it will turn nut and washer on top, so not to tight i think, but there is no slack. maybe nip it up a bit?
