weak steering after getting sky fly gt3b
gobigorgohome
my steering on my rampage mt is very weak now after hookin up new controller it takes for ever to make a turn the servo percentage is on 100% not sure what else it could be?
Does the servo move slow or is it not moving far enough. If the travel distance is too short you can also adjust the end point. Also check the trim. Make sure you have both steering servos hooked up if you are running duals.
Mine turns awesome with the flysky. Check your adjustments and the doublecheck them and try again. Youll get it figured out...
might be a silly question, but your servo saver springs are tight?
spent hours before messing around with servos and controller, when achally the servo saver springs where just lose
The MT has two adjustable servo savers. Follow the link that goes from your servo to the steering assembly and you'll see it. It's just a spring with a threaded collar on top. You have one on each side. Make sure they're not loose.
thanks i looked into that and found that the arm has a hairline crack so its flexin instead of turning now i gotta spend more money damn lol
If you have done that and still have an issue check your EXPO also....
