What did i do
Hope you don't have many neighbours if you plan on dropping the G320 and a tuned pipe in it, mine is so loud it's antisocial...lol
He never showed the rear of the drive shaft to see if its bent now if you was talking about the front dogbone its at an angle coming out of the diff cup this is on a losi 5
I was going off of what I could see in the first video, your brake disc is wobbling at about the same cadence as the noise. Mine did that when I ended up with a wobble in my rear drive shaft. I would pull the center diff and see how true its spinning. Past that, may want to check your bearings in both the pinion housing and the center diff.
