What direction does our 2stroke engine run in?
My tip for easiest way to verify is look at the pull start cover . Note that as you are facing the PS housing the rope exits the housing on the left, so when you pull up on the rope, that causes the PS pulley to rotate the crankshaft clockwise. That being said , looking at the clutch side it's opposite and the crank rotates counterclockwise.
Its anti clock wise trust me we've been over this??
