Trip
Zen g260 stock in my FG MT. It ran great, but I was convinced by others I needed to put on a 28.5 bb kit, boy was I wrong!
The bb kit was simple enough to install, but it never ran correctly. One day it just wouldn't start so I dicked around with it and gave up. I let it sit for a few days and I pulled the air cleaner off and found some scratches on the piston. So I yanked the head and the piston was FUBAR.
Swapped back to the stock head and it was better for about half a tank, then it too started acting up. I again pulled the air cleaner and I saw some scratches on the piston. Pissed off, I put the motor on a shelf for 3 years...
Tonight I decided to pull it apart and here is what I found...
The reason the motor didn't want to run was because I had the intake gasket installed incorrectly and had the pulse hole covered by the gasket. Otherwise it probably would have kept running, at least for a little while. The compression is still great. Better than my CY GP290 has ever been.
Whatever it was that wiped out the bb head was still in the case when I put the stock head back on, because these pics are identical to the pics I took 3 years ago of the bb head. I never cracked the case apart..
This is an old pic of the bb 28.5 head from 3 years ago:
Back to the 26:
The exhaust side looks ok really, the scratches are superficial.
The circlips are still in the piston, incorrectly installed I see, but nonetheless they are in there.
Is this common for this gasket to be hanging out like this? I've never taken a case apart.
Any ideas what would have caused this? I will tear the case apart tomorrow to see if there's anything in there. Has anybody seen anything like this before?
Thanks guys,
Trip..
Back to the 26:
Thanks guys,
Trip..
