what is THE strongest loctite?
Thread starter #1
Z.hb71
Likes
1,311
From rainy, boring, humid, Manvel, Texas
what is the strongest loctite? i got a fitting on the crankcase of me 70cc and i don't want that coming out cuz if it do its game over for the engine, i don't mind heating the hell out of it to get it out, pretty sure reds the strongest right?
crucialRC
Likes
533
Maryland, USA
I always thought red was the strongest but I've been reading different on this sight. I've always thought green-low, blue-medium, and red-high. I will look at mine when I get home.
crucialRC
Likes
533
Maryland, USA
Yeah it says red "is the highest strength."
Looks like green is under red with medium/high and wicking capabilities, then blue as the lowest strength at medium.
Looks like purple is lowest strength for soft metals.
Whoduh
Likes
417
Fairfax, VA
What is the correct amount of torque on the bolts/screws per the engine builders specs?
Thread starter #10
Z.hb71
Likes
1,311
no idea, contacted alx long time ago for torque specs and they never responded. no idea whats going on with them
Green is metal lock. It's made for press fit and it's what you would use.
its threaded not press fit
Thread starter #12
Z.hb71
Likes
1,311
It's what you use when you never want to take it apart again
I have a bottle of it here somewhere I'll go find it and take a pic
It's more a retaining compound but it never comes out. Red you just heat up. This stuff basically will tear the metal out.
EDIT: ill use red then cuz if a fitting gets screwed up i don't want to have to drill it out, red seams just fine. thx for the info
crucialRC
Likes
533
Maryland, USA
It looks like the green Loctite threadlocker brand and green Pioneer brand are different formulations
1Coopgt
Likes
560
Rochester,NY
This is the stuff I mentioned last night . We had to heat the hell out of the parts to get them apart .
Goes Purple ,Blue , Red there a couple different versions of Red and then Green. There are also versions that use primers for when you are putting dissimilar metals together ( Stainless and Aluminum ).
Pictures of the parts you're putting together and what is their function ?
Thread starter #15
Z.hb71
Likes
1,311
Ok srry for late reply, I was really freaking busy, but I'm off for the next 2 weeks!!!!!!๐Ÿ˜๐Ÿ˜ƒ๐Ÿ˜› So back to the matter at hand, here's what I'm tryna loctite 15453501849276444598363201311435.jpg it's not fully pressed in just for photo sakes, it's a pressure line thingy that goes to the carb for the diaphragm (think that's the purpose)
TODD
Likes
15
Am I missing something here? Is the case not threaded for it to thread into if it goes there? Was just curious why you would need to Loctite in it if it is threaded.
