What should i do🤷‍♂️
Pics of various setups? Im not up on baja stuff and whats the benefits of either setup
Carbon fiber bonehead = lighter than stock...stronger
Kraken chassis lighter .....not sure if its stronger🤷‍♂️ but less weight =more go
The 5t arm mod will give me more stability 👍🏻
Time for a losi/ baja outlaw then🤔
Happy The Rock GIF
This kid ^ :LOL: ....ill send you a bent chassis to straighten tell me how you make out with getting it to be straight again....I use a 50 ton press to straighten chassis.. good luck
Got some choices to make 🤔
Should upgrade 34 baja with the full bonehead set and kraken chassis👍🏻
Should I do a 5t arm conversion with irp links black 5t 2.0 rims and flm cvds👍🏻
Or should not do either 🤔 😆😆😆
Leaning towards neither but at the same time I don’t have a solution for you. Maybe a new kit something different or a carbon Baja with a 40gt
