What spares should I get before I buy?
evildomain
I'm interested in finding out what spare parts I should buy at the same time I purchase my Rampage TT? In other words, what parts break the quickest and most often? That way I won't lose any run-time when I'm just getting to used to driving the buggy.
The F/R Diff gear set, T/B servo, Steering servo, steering servo arm if u using plastic. And a 2nd set of front lower arms wouldn't hurt. If you are getting the V1 that comes with the upgrade kit the diff parts and A arms come with it.
If I get the 28.5cc headkit should I get the metal gears? Figuring out gear combos seems a bit confusing:eek:. With that headkit will I lose low-end torque but gain high end speed or the other way around?
Thanks for the help:)
only if the head kit is ported for high end or low end will it change. the pipe will change the high or low end also. I would get the metal gears the 28.5 has more horse power and the stock gears don't hold up to long my sons truck has the big bore 28.5 it eats up the stock gears in 2 to 3 tanks of fuel. My truck is a 23.0 wth 24-35 MCD gears and 2 25 stock redcat gears and i have ran 5 or 6 tanks of fuel and they still look good
