What the blip! RPM surge-video
Xicaque1
I move a lot thanks to the government
Group,
So recently my RampMT is doing this thing that I guess you can call RPM surge...
This only happens when I apply the brakes as to stop the trk and then when I release the brakes, the rpms shoot up.
I need help. :o
Thank you in advance.
Here is the video. It is about 33 seconds long. I guess this forum will not let you post video... If you click on the "pic," it will prompt you to open or save it. I promise you is a video and no trojan garbage.
Thanks again for your help.
Re: What the blip! RPM surge-video
video didn't work for me, but it sounds like you need to check your T/B linkage
No biggie dude.
Watching the video I can see your linkage binding. As you let go of the brakes the servo centers. The throttle linkage is pushing on the carbs throttle. Loosen the screw that holds the throttle linkage to the servo arm. That should resolve the issue.
Click on the image. It should open up the photobucket page. You can then play it from there.
Xicaque said:
Group,So recently my RampMT is doing this thing that I guess you can call RPM surge...
I need help. :o
th_6896C1C2-8E1B-4EF7-9E92-780594302E61-2634-000001E296BBA909_zpsf8239634.jpg'%20alt='th_6896C1C2-8E1B-4EF7-9E92-780594302E61-2634-000001E296BBA909_zpsf8239634.jpg'
Did you get it figured out?
Hey RCDAD!
I have not had the time at the moment. Work won't let me play with my toys.
I looked at the video and I think you are on it. The section closer to the servo seems to drag... I hope to be off tomorrow and I will try to get to it. I will post the findings.
Thanks for the help.
Rob
