Dirk squarejaw
- Reaction score
- 0
Anyone else had this problem? The amount of camber with the car off the ground vs on the ground is probably 3-5 degrees difference and its not in the upper arms because you can grab the wheel off the ground and tilt it back and forth and the upper arm and knuckle don't move. It has to be in either the bore for the bearings in the knuckle, cheap Redcat bearings, something else or a combination of problems.
With the wheels off, it doesn't seem that bad, but with the wheels you can really see exactly how much movement there is with the extra height of the wheels/tires.
BTW, this is a Chimera (actually started as a new XB rolling chassis from Ebay) with 4 tanks through it and Baja 5b fronts all around and street tires.
