Which Savox servo for Dunerunner steering and throttle?
jandmt
Anyone here use Savox servos on their 1/5 scale? Which model do you use for steering and throttle?
They make 2 servos for 1/5 scale models SV-0235MG which has less torque but is faster and SV-0236MG which has more torque but is slightly slower. Both of which can be seen here http://www.savoxusa.com/category_s/55.htm
Which model would you use for steering and throttle?
Thanks!
Savox Servos
I am using the Savox Sevos:
On XT = CS - 1232 SG for throttle
SV - 0236 MG for steering
On MT = Same except 2 steering servos.
On Dune Runner = CS - 1232 SG for throttle
2 High Tech HS - 5755 MG for steering
Have had good luck with all but may prefer the savox.
In the winter for on ice use I put dual steering servos (savox) on the XT to help overcome the straight line pull of the screws on the front.
Bill
Thanks. After much research, I'm trying to get my hands on a pair of Muliplex Rhino Pro 4 HV Digi's. Can't beat their .8 sec speed at 7.4v with still a very decent amount of torque.
Just an FYI. The savox SV-0235mg and 0236mg are not a direct fit on the dunerunner. It's 6mm longer requiring modification to the servo mount.
Hitec 5765 is a direct fit though. Probably should have gone with that, but I wanted the extra torque.
jandmt said:
Just an FYI. The savox SV-0235mg and 0236mg are not a direct fit on the dunerunner. It's 6mm longer requiring modification to the servo mount. Hitec 5765 is a direct fit though. Probably should have gone with that, but I wanted the extra torque.
The Hitec 5765 MH isn't a direct fit :(
