- Reaction score
- 27,691
So I'm thinking about using a AN style screw on line and fitting for the pulse on the 70cc, just a idea, instead of a pressure/Barb push on fitting? I think it's Overkill but I was just thinking about it.
6mm Inner diameterCorrect me if I'm wrong . The pulse tube is for getting vacuum from the cylinder to the carb correct ? If so just make sure you get everything sealed in the hose couplings really good . The last thing you want is a leak . It will be hard to find if it leaks. It will look cool. What size tubing are you going to use ?
Figured as much ? don't think they make it that small either. So I'll Just stick with the barbed fitting, maybe down the road I'll do this just for the cool lookOver kill by a long shot imo... would look very nice though.
Serched those, can't really find anything, I'll just stick to th standard Barb fitting ?found a good deal on them, $4 for 5 Barb fittings on fleebay.-4 would be about the smallest I know of..... but there are stainless braided brake lines? I don't know if they would work proper for a vacuum/ pulse hose.
