xb differential lube
cordy
suburbs of chicago
What are you guy`s using for lubricant in your xb rear diff? Will lithium white grease work? Do you just lube the gear and pinion? I am putting my diff. back together and trying hard not to explode it a second time.Thank`s.
I use 1000 wt at front and rear and handles great. Also, I use white lithium grease at the ring and pinion, makes them last forever
