h3llkittylvr
- Reaction score
- 4
So I put in a full stroker engine case and head for the 23. Go to start, there is no suction of the engine drawing air/fuel into the cylinder, instead it is getting blown out of the carb. I have spark, I checked the bypass hole on the carb gasket. The only thing I am unsure of is if the "arrow" on the piston is facing the exhaust. Looking at the old engine assembly, the piston is the same on both sides of the skirt, one side is no different then the other. I am not sure if this makes a difference. There is no fuel in the exhaust either.
CONFUSED??!!??
CONFUSED??!!??
