zenoah g230rc
madforRC
New Member
bridlington
if your in england what carb settings are you using eg idle screw 1turn
highspeed 2 turns
low speed 3turns
any help would be great many thanks madforRC
whizzy
paisley
lsn should be 1.25 turns and hsn should be 1.5 turns then adjust your idle to suit i normally adjust idle till it starts then give it .5 of a turn
madforRC
New Member
bridlington
thanks guys,Ive printed the manual already and changed the needle settings accordingly but still have no luck starting it, so im going to buy a new spark plug.Where can I get a spark plug from. My local model shop has stopped stocking 1/5 scale models. I live in the united kingdom (England)
Timmahh
Bajastafarian Madnes
PLUS member
Michigan
most small engine shops. lawn and garden shops, hardware stores. anyplace that sells weed whips and chainsaws should be able to get a usable plug. make sure it is a Resister Plug, ie. has an R in the model number for the plug.
T
