Yeah 1191 not 97, for some reason I can never remember the model off the top of my head.
curious of how much exhaust, transfer and intake port duration the esp topend has at 0,022” clearance.This thing is WAY faster with tons more torque and top end , different motor now !!!!
I have NO IDEA ???? total loss , would have to ask Doug @ ESPcurious of how much exhaust, transfer and intake port duration the esp topend has at 0,022” clearance.
with my ported rovan, i got 180, 128/119 and 155deg respectively with 0,021” squishband clearance
Have you ported a Rovan head yet ?? any good ? just curious , I noticed I had a bunch of blowby on my ring at the slot so it was to small , I think if you re ringed and ported it might be ok ??his business.. wont even ask
i have my own port duration numbers... just would be good to compare them with what professionals are using.
when my rovan top-end dies, i'll replace with zenoah. have the genuine set already
View attachment 66130View attachment 66131
WTH that looks like crap man ! what oil are you using it looks burnt to me , did you check the ring end gap ?yes. i ported the rovan head. i did not want to invest too much into my first porting work hence i went with rovan, not zenoah. i’ve just rebuilt it after 18-20 liters, replaced all bearings, both oil seals and the ring (with zenoah), refined the porting and put it together.
i saw signs of blowby at the flywheel side, but thought it was the semi-syntetic oil made it. (...and hell a lot of carbon deposits too)
i’ll check the diy dyno thread...
That looks like a motor that was sitting outside for 20 yrs !That seal has been going out for a wile, I would suspect it was a small air leak as well. Whatever oil your running is garbage. I haven't seen build up like that in a properly tuned engine in years.
And leaning it out at the same timeyes... certainly w/o leaking it doesn’t get the oil mud
when starting, the ascending piston pulls air not only through the intake track, but through the broken seal too... imo
making the starting difficult
alsoAnd leaning it out at the same time
