- Reaction score
- 27,691
- Thread starter
- #2,281
That's seems too cheap but idkNo clue, only ever bought brand new rtr. Id imagine a stock roller shouldn't be much. 500 mabey ?![]()
Bone stock 700 with or without motor,?Bone stock $700 in good shape
Semi built $800+ pending upgrades
Fully built rcmax etx $1500 plus
Ok, if I got summin with an engine for 700 I could sell off the poop engine to recoup some $$ and drop my obr in ?Seen it both ways. I mean the stock engines are worthless basically unless were talking g320 or something.
It seems clean rollers fetch just as much as if they had a standard engine in them
Weeeell I might have went crazy cleaning ? freshend up all my de Anodized aluminum ? I also found some oil in my clutch carrier, possibly from the bearings, so maybe that's why the clutch got so hot
Damn it's so clean ? makes me wanna keep it now ??
Lmfao, all nice and tight ? didn't say I was keeping it , didn't say anything in Fact ?Hmmm. Should we take bets what breaks next or what comes lose because he forgot a screw
Lmfao, all nice and tight ? didn't say I was keeping it , didn't say anything in Fact ??
Possibly , but it's so nice now ?Cleaning it up for ebay ? we already know
Whoever he ships it to is gonna end up with a box of loose parts. Thing probably sounds like a 80's Camaro door when you slam it, or those monster dashboards just driving.?Hmmm. Should we take bets what breaks next or what comes lose because he forgot a screw
The oil on your clutch carrier will be the grease from your bearings caused by the clutch getting so hot.Weeeell I might have went crazy cleaning ? freshend up all my de Anodized aluminum ? I also found some oil in my clutch carrier, possibly from the bearings, so maybe that's why the clutch got so hot
It’s better to not pack bearings with grease. pop the dust shield off and clean them, then all you have to do is add like 2 or 3 drops of machine oil. It will cause less friction and never leak out onto other componentsThe oil on your clutch carrier will be the grease from your bearings caused by the clutch getting so hot.
The bearings might be toast now but could possibly be repacked with grease
Is this true in all bearing applications? Ive always packed my bearings on my larger machinery. Timken bearings always recommended it in the literature.It’s better to not pack bearings with grease. pop the dust shield off and clean them, then all you have to do is add like 2 or 3 drops of machine oil. It will cause less friction and never leak out onto other components
That doesn’t apply to all bearings, When I was in the service we would pack large bearings for like wheel hubs or anything similar with grease. Small enclosed bearing with dust shields especially bearings that benefit from low friction thresholds I’ve never packed with grease. A bearing in a 1/5 is much closer to a bearing in a skateboard than it is to something in a car or large piece of machinaryIs this true in all bearing applications? Ive always packed my bearings on my larger machinery. Timken bearings always recommended it in the literature.
Bearings feel just fine. The seals look fine tooThe oil on your clutch carrier will be the grease from your bearings caused by the clutch getting so hot.
