Finally found a bash site
xraysrt6
Piedmont SC
Moved to Greenville SC in Sept and have been trying to find a place to bash.
I found a field that is like the size of 6 football fields with lots of hills and dips for jumping. I finally have run a little over 1/2 gallon thru my new Gizmotor and man in the last 2 tanks this motor has come alive. I am running 19/55 gears and this thing just tears up the grass with a set of hostile MX tires. Im thinking of trying a taller set of gears to tame it down a little off the line. I have to feather on the gas otherwise I just end up doing donuts. Any suggestions which gear ratio. my motor has 7.5hp with an 8k clutch. Okay I have the vertigo EAC clutch system and they do not make a 20 or 21t pinion they go from 19t pinion straight to a 22t pinion. Does anyone know where I can get a 52t spur gear?
