I'm in the process of building a 45" jetboat using a 5694 1000kV motor. The connector ends on the motor measure as 8mm. I sourced an 8mm connector set, but the new connectors slide very easily over the spring connectors on the motor wires. I don't know if spreading the tangs/fingers to create a tighter fit is a good idea or not.
The pairs of connectors in the 8mm set have normal friction/fit with each other.
Are the connectors included with these motors a different sizing? I'm a noob with electric systems; virtually all my RC gear is nitro or gas.
Thanks!
Thanks!
