- Norwalk, CT
Hey guys, anyone here a guru on Flysky programming
I recently switched to the the Noble pro
I have a dual steering and dual throttle/ brake setup programmed in the radio
The Transmitter is on latest software, receiver is the Fgr8b
The start channel is set to 3, so 3 and 4 are the steering servos.
5 is throttle/brake and 6 is brake. Now for my problem/issues
I‘m trying to add the Idle up and End cut.
I’m using the Vr1 switch to activate the high idle and TR3 for the trim,
it all works in the radio and in servo view I see it working but no servo movement.
I tried to use End cut and that even though I see it working in the radio again the has no affect on channel 5.
I installed the killer bee kill switch on channel 7 and assigned it to Sw1 and that works as an engine cut.
I tried to mix the original throttle to Chanel 5 but that had no affect on anything.
I really need some help guys, what am I missing.
