Brooklynhalo
im running my truck for about an hour along the inside frame inner wall i am getting a layer of oil some of it also on the transfer case i clean it up after every run i check the exaust connection where the gasket is at and its dry motor is clean i thinking its coming from the rubber connection with the spring any of you have this thanks or has delt with this
