Dirtblaster
Any recommendations for 1st upgrades?
Link for kill switch pleasekill switch, then replace what breaks.
I use this on all of my cars. Located in the USA. Not sure what other sources are there for different locations. The device works well and will shut down the engine even if you turn off the receiver power by the slide switch under the battery box. It will also shut down due to low battery voltage, signal loss and receiver malfunction. Basic function shorts out the ignition coil just like the push button on the engine. There are other kill switches out there but I am not familiar with them.Link for kill switch please
dude , go and introduce yourself in the welcome/introduce yourself thread,Any recommendations for 1st upgrades?
air filter and kill switch i use the rovan one works fine so far test it each drive.Any recommendations for 1st upgrades?
