smartech uno
- Israel
Thanks for all who tray to help me
I followed the explanation,and the video but I do not know why I have trouble every time to to start my engine
the prosses i do:
fuel ok half tank
spark ok i replace with new one
i open the chock (the read buton on 9:00-horizontal position)
i pump
i move the chock to vertical (6:00 )
no signal (i tray 5-8 time with the pull start)
car type smartech uno 28 cc
what is it so hard ....![]()
but thay just store how can they use engine(use it in a cheaper version marder now )?its came from the factory-No?It is made by carson the 23cc pt engine and smartech just put there name on , Rc online de use it in a cheaper version marder now ! But only in the cheap one , its also in all the carson touring cars . Your right mate its a three bolt with no upgrades but you can get heads and rings &stuff but its not worth it as you can buy a cy or zenoah off eBay for less than a repair , I have the smartech spider and I'm just gonna rally that we engine until I get an engine ready to replace it but you need the gear carriers , gears , lay shaft , and engine mounts as the pt engine is different in those areas .
Hi mate !ok
so i try to start the engine its not starting
the prosses i do:
1-the pump is full with fuel so i live it as it
2-the chock are on vertical Position
3-i start with the pull start 3 time its do not start
is it me ? or this car engine are Problematic (i have the car one year)
Hi mate !
Wasn't your car going ok before you tryed to fit your kill switch ?
Did you put in a new spark plug ? Check your air filter , carb and exhaust to see if everything is tight ! Set your needles as per the email I got from hobbytheck ! I done it on my spider and one screw open on each needle starts my spider so they must be right but , can you tell us if you fitted your kill switch and was the car running before hand and sorry for saying mate !
Could you start a new thread on your problem as this thread is for tuning information and its getting blocked up by us !
Cheers
Rob
Could be an ongoing problem why the forum is intended to?
If you would like further assistance to me?, I will describe what I checked
Hi mate
If you want the people on the forum to help you then you have to help us to help you ! And if you want some help then people need to find your posts , and this thread is called the secret of engine tuning ? So if you make a new thread called " my engine won't start " then everyone can see your posts and comment on what they think you should check and Theyr opinion of what might be wrong ! Sorry if it sounds cheeky but were only trying to help you !
Cheers
Rob
ok
the prosses i do:
