Ferrebee88
I really like the looks of it. Anyone have one? Any cons to it besides the price? Would I need to get the A-Arm extension kit as well?
I know the VEKTA cage is separate and would not work on a Baja. I was just pointing out that my Baja will be electric so there may be a large emptiness since the cage was designed for gasBaja 5B and Vesla can use Kraken TSK-B and SX5 cage, Vekta has an own design for the cage
Your picture has convinced me to get it and the extended arms. That looks sick! I noticed that the Kraken arms kit says that you can't use the included dog bones with baja kits that came out after 2014. It pretty much said "oh well, you can just get some other ones to fit the larger drive cups". Did they just not update their website or do I need separate dog bones as well?Sexy cage looks best with the extended arms. Solid kit just get the quick release so you can take it on and off easierView attachment 87998
I run flm extended arms but I believe the kraken arms are extended so you need extended dogbones also for themYour picture has convinced me to get it and the extended arms. That looks sick! I noticed that the Kraken arms kit says that you can't use the included dog bones with baja kits that came out after 2014. It pretty much said "oh well, you can just get some other ones to fit the larger drive cups". Did they just not update their website or do I need separate dog bones as well?
It would seem that the extra $100 for the FLM extended arms is well worth it. It looks like I will also need to get either the FLM super duty driveshafts or the FLM hardened diff shafts to go with it. Any advice on which one to go with?I run flm extended arms but I believe the kraken arms are extended so you need extended dogbones also for them
I've done plenty of cartwheels on my 85cc Baja with the alloy FLM arms with Taylor ti pins and didn't break a thing.I am assuming that in a situation where your Baja is doing cartwheels like it's part of the circus the plastic Kraken extended arms would be preferable.
