Deeside Sunday 26/09-
If it turns out to be correct I will be down around 13:00, that is if the car is back together. I have slight banana shaped front shock shafts. Not leaking and still getting full stroke so maybe OK.
Whats the O/D?
J.
Not Sure. I have been talking to Ross Mods and MCD have two versions of front shock shafts and to make sure I have to take the shock apart and measure the length of the shaft so they can tell. The front shafts on the RR V4 are very similar in length to the V3 rear shafts.
I'm a bit annoyed that Ros Mods do not keep a record of batch numbers v car versions so they can tell me without having to strip it down. Mine is only about 6 weeks old so any right minded person would think mine are Version 2 rather than version 1 shafts for the V4.
i will be over this sunday, might have a couple of newbies as well (the deeside curse springs to mind)..:lol:..
be there about 1
Bring on the bash fodder ! ......erm.... sorry... I mean newbies !!!
We will see if Deesides "Newbie Gremlin" rears its ugly head !!!:w00t:
i will be there,my first time:D
whats it called ""the virgin deeside curse"":lol::lol::lol: i hope not!!:cup-1:
can someone put the post code up for deeside
Its had quite a few victims :scared: Mine was a runaway straight into a rock after less than 5mins. Screw came out of servo horn & jammed the throttle wide open. Jackrod broke his the other week & Im sure Charlieboy, Paul B and a few others have felt the curse. There must have been 6 or 8 back in the boot of the car within 5 mins :lol::lol:
Good luck......:clown:
ch5 2nu is what i use mate but you need to go straight over two roundabouts then 2nd left i think then first right it will make sense when you get the if not ring me and i will direct ya ginge
