spark
michaellfc95
liverpool
i started my baja b4 after rebuild and it started fine and when i reved it with the wheels of the ground there was sparkes coming out of the clutch bell any way i took it apart and there was a lose bolt so i tightened it and now when i rev it , it sparkes then its fine then when i let go of the throttle and do it agen it sparkes it seemes to be when the cluch it kicking in is this normal
mike
whats meat ? :S
mike
Kreb means is there any clutch shoe left or is it down to the metal?
I recently blew both shoes out of my clutch, the car had been run for about 3 to 4 tanks when it just stopped, after stripping down the shoes fell out of the bell completely apart from the clutch, virtually no wear on them the adhesive used at manufacture just melted.
thanks for the help iv sorted it i put it on the stand to take a vid of what wa happinging with the spark and i reved it and it sparked once and now its not sparking so what ever it was its fixed now thanks mike
i would take a look in there anyway just to be on the safe side. lets say there was a screw that had fallen in there and that was causing the spark, it may not be sparking now but you don't know if it caused any damage. take a look just incase.
