running problem.
pablo
slipknot central
just replaced my worn out cy26, for a zenoah g230 fitted a new carb, coil and flywheel, and a dom pipe. started 2nd pull and ran ok for about 10 seconds the started a high idle, checked for air leaks and there is none? i had this problem with the cy26 allso now i,am thinking is it somthing to do with the fuel tank? the vent hole isn,t blocked and the clunk is clear allso.
