Are these long enough!!!!
dwarfy
Rossendale
What do you reckon :clown::clown: Should look ok when ive cut them down a bit & its got smoke billowing out of both sides :cool2: Short pipes = LOUD!!
They are the warmest carry handles on the market :clown: They come with optional skin grafts :clown:
Just screwed them in to mark up & just cutting them down now.
Thats better! I can get the shell on & off now :) Cant wait to give it a blast now :cool2:
I will post some when I get 5 mins. I bought the x-can off Voo & it already had the pipes out of either side. The pipes that came with it were home made (not by Voo it was 1 he bought to break for parts) & bent around the body shell to rear exit under the wing. Looked ok but were a pain for removing the shell.
Here you go mad. You can see the existing 2nd outlet on the RH side of the can. This has been blanked off.
How is the performance with that contraption? I am not a big fan of my X can, but it is better than the crap stock muffler.
It def has more bottom end and mid range and generally seems to rev more freely than the stock can. Sounds good too! I also like the fact that I don't have to hack the shell away like with a samba for example. The car is all stock apart from minor mods so no ally to weigh it down. Its lively enough for me anyway!
Alloy is too heavy and once it's bent, it stays that way! Plastic snaps back into place.
Plastic is good :D FG plastics are very durable and can take a good beating over & over and are cheap to replace when they do eventually give up so I don't see the point in changing. Just my preference.
