2.4ghz radios
pacman696
hull
hi all
does anyone know if these radios can bind to any receiver. ie i have two sets of code 3 ch 2.4 which i like, and four cars, and just ordered a new car but would like to use just one transmitter, and which ever car i would be using just bind them ,is that possible.........phil
hi all
I also have this set and think its excellent!!
You have a 15 model memory so just use 1 of the spare memory settings for each car and you can program it to suit each cars requirements. You will have to bind to each receiver when you program each model settings and this should be stored with the settings so you don't have to re-bind each time you change cars, just switch to the relevant model memory. Hope that makes sense :rolleyes:
thanks mate,i have been looking for receivers but i think they have changed and not sure if they will work, mine are model cr138 and can only find a cr152 and they have a button on? but i think they spot-on and i only like the sticks,but i wonder if all makes are compatible?.......................Phil
The bind button is just an upgrade so you don't need the bind plug (which I have lost twice!) but ring either Rossendale Models or Modelsport for advice. I have ordered from Modelsport recently - the service was top notch and the prices are amongst the best in the UK at the moment.
http://www.modelsport.co.uk/index.php?product_id=38219
thanks mate,i too have lost the plugs on both lol,have you tried the abs braking ? i like rosmods,its better to go rather than order i think,i spent two hours in there and £300 on stuff i thought i might need and for just in case,and the guy in the shop gave me one of them free parking things with a clock on ...................phil
Check with them before you go for your receiver then cos Im sure they don't stock the Core RC sets now. They have gone over to the Etronix now which seem to be a rebranded version - identical casing, receiver etc. They will still give you good advice over the phone tho.
The parking disc :lol::lol:
cheers mate , i will email them now......................phil
