ive heard of people doing this BTB but never tried it myself, is this proven? is it a better bite?
So should I use the stock spring with the new clutch shoes. Why do they call it a high response clutch if it takes more rpm to engage. The stock clutch has better response.Thanks for all the help.
When you say install backwards do you mean just make the arrows face in the opposite direction. Thanks for the info
Yes Sohan,it works.I run my standards like this but run the adjustables the right way for obvious reasons.
J
thanks james, might give this a try one day. would this decrease the stall setting? (using an 8K spring on std set up?)
This lowers the clutch engagement slightly. That way its not as high reeving as the stock set up. Thats because the way the clutch is now moving it flips out instead of drags out. Less slipping and sliding into the bell.
