Do Not miss your chance to be one of the first on the block to pick up one of these bad ass mofos!
the stock motor is ok for brushed, great for the younings, heavied fingered, and general nub, or for the stock class at the track.
i put in the MM/5700 and WOW what a tiger. can be hard to keep the front down if your too heavy fingered. buggy handles Very well out of the box, but i made the front and rear shock adjusters a bit softer (raised to reduce spring tension ). raised them about 1/4 in in front and 1/8th in back.
WOW what a big differance. now its planted on rails. once it straigtens out. pin it to just prior to breaking the rear loose, and it flipping FLIES. give it just a bit more, and the front end just lifts right up. even at about 30.
check it and try one, or don't, cuz if you try it, you ll want to buy it.
