Baja Donuts anyone?
takeoff
im new to the baja and i have only had it a day or so. i was wondering what size engine you have? is it 23cc or is it more. i am curious because i cant get mine to launch like that. i have the 23cc. is that why? should the 23cc still be fast off the line or is there always a little hesitation? your baja is impressive.
I believe to improve the take off on a 23cc is to fit a stiffer clutch spring....so it dosnt engage till a higher rpm. Not sure you will get wheelies from it though?
Depends how many tanks run through. it takes a few tanks to really improve. Remove the stinger and gut the muffler is a quick and cheap way to get more power.
LoL thought i might show this dude the real stuff.
Regarding the Q`s. The bog is best cured with the 813walbro carburator.
A pipe and stiffer spring helps to. Making wheelies on tarmac with the 23 is close to impossible, though ive seen it happen. Must have been a fluke.
I run the 30,5 and with it the Baja launches...
