J-Revo
Not yet tuned in, first tank of gas
Great choice of engine, i got the 30.5 3mm 7hp and love it
Make sure you use 927 castor oil mixed with your fuel for long life of the engine as recommended by obr it also has a cleaning detergent added so it cleans the engine as you go
Troy
Nice!! that thing sounds great. Did you have to do any special mods to the engine to get it to fit or was it a straight install?
44/20 on monster truck wheels is plenty,around 52mph,that engine could definatly push 42/22,easy,nice work mate,.Takk takk, er veldig fornøydI'm very happy the way it performs now, I major step up from the ESP engine.
I have it geard at 44/20 and I think I'll leave it at that. The clutch bell, gear plate and smaller gear gets a bit hot. I tested it with some spit (old nitro trick) and it doesn't "boil", that way it should be under 100 celsius. Is it normal that it get's some what hot at that gear ratio? I have installed an alu gearplate, so it should be ok.
