hi,im sure ive seen bajas doing 50 mph with those gears, but they had either tuned pipes or ported motors, you need the gear ratio as well as the power to pull a certain speed. i think with the x can and a 26 id agree and say around 40mph,if you was to change the pipe,im sure you could easily top that. my mate has a 28cc baja with a dom,that does over 45mph.hi guys i have a baja with a 26cc cy engine large x port x can with 3" stingers 668 carb 57/17 gears what mph will it do?
yes i agree,its more of a torque pipe, i use a fg marder jetpro v2 which is a top end pipe and gives nice power up in the rev range, some of those fg's that are running mid 90's (mph) are using the same pipe,the only problem is unsilenced which makes it stupidly loud, sounds nice at full revs but a bit too much sometimesIf you are looking for top speed need a good pipe made for RPM. The rear DOM is not a good choice for top speed. If you gear it up and get a good top end pipe you might get mid to high 40's but with a stock motor it is going to take a while to get it up there with tall gears. Whit what you have I say maybe low 40's. Keep in mind to scale MPH that would be around 200 MPH.
About the best I have seen with a HPI style Baja is about 80 MPH and the record was on a FG Baja 97MPH.
Where abouts in Lancs are you?
