5T to a 5B is it as easy as it looks?
Okay dumb question.
To make my 5t into a 5b do I just remove parts till it looks like one?
I would assume just put a 5b body on it and its done?
Any idea of what parts? Maybe the front body mounts?
I'm going to download the 5b manual maybe that is the key.
Convert your 5T to a 5B
Under Guard # 85443
Drive Gear 20T # 86486
Roof Plate # 87430
Guard Deflector Set # 85442
Wing Set # 85452
Alloy Polished Tuned Pipe Set # 87401
Baja 5B Clear Body # 7560
Roll Bar Set # 85439 (for the wing mounts)
HPI Baja 5B Dirt Buster Ribbed Tyres - Mounted on Front Black Wheels # 4736
HPI Baja 5B Dirt Buster Spiked Tyres - Mounted On Rear Black Wheels # 4737
There ya go!
J.;)
The 5b is about 6 pounds lighter then the 5t. Much of this is in the tires. Now on the 5t in the transmission it has a lower gear then the 5b. Drive gear on the lay shaft in the transmission on a 5b is 20 teeth and 5t 19.
