Bearing sizes
The size of the crank bearings is 12x28x8. I would tell you where to get them if you where in the states for $3.55 each US.
Cheers 46,I have a bloke over this side who can get them cheap.
Thanks for the info.:cup-1::cup-2::cup-3:
J
J
I would guess they are but make sure they are good quality and will with stand the RPM. Do you know what brand they are? Some really good ones are the 6601 C3 Nachi. They are the ones I was talking about. The funny thing is I am running Team Fast Eddie cause I keep getting them for free. LOL But the next time I have to buy them I am going with the Nachi.
Item: 6001 Nachi Ball Bearing
Type: Nachi Deep groove Ball Bearing
Radial Clearance: C3
Dimensions: 12mm x 28mm x 8mm/Metric
ID (inner diameter)/Bore: 12mm
OD (outer diameter): 28mm
Width/Height/thickness: 8mm
Size: 12 x 28 x 8 mm
Quantity: One Bearing
Dynamic load rating Cr: 5,100 N
Static load rating Cor: 2,390 N
Limiting Speed:
Grease Lubrication: 28,000 RPM
Oil Lubrication: 32,000 RPM
Made in Japan
i'd highly recommend getting ceramics...after the first time i used them i was a convert, they do make a difference in quicker spool up and about2k more revs top end, 3kwith a lightened piston...wellworth the extra coinage i reckon
